Tio1's avatar
Tio1
Buy a cable modem router
Hi community people;
I have a cable/satellite box, and my TV is connected with a HDMI cable.
I would like to buy a cable modem router, model C 7800 Nighthawk. My question is, how to connect to the router: is Via HDMI or Coax cable
I will appreciate your answer Thank you!
  • C7800 or newer CAX80/30 gateways needs Cable service with ISPs such as Xfinity/Comcast, Cox, Spectrum, etc.
    It needs to be directly connect to ISP cable and will NOT work with Satellite providers such as Dish/DirecTV, etc
  • > I have a cable/satellite box, [...]
       Thanks for that detailed description.  Connected to what?
       Why?  Are you connected to a cable-TV ISP?
    > [...] Via HDMI or Coax cable
       It uses a coaxial cable from a cable-TV ISP.
          https://en.wikipedia.org/wiki/RTFM
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual (at least).  Read.
       "satellite" makes me think that you're looking in the wrong place.
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    • Tio1's avatar
      Tio1
      Thank you vkdelta for your post!
      I already bought a Netgear model C1900 cable modem router.
      I think this router works for me.
