Hang94
Dec 17, 2015Aspirant
[C3000-100NAS] 2nd and 3rd Light just keeps blinking
Hi All I bought this modem/router back in april 2015. it stopped working on October 2015. ISSUE: 2nd and 3rd Light just keeps blinking, 1st and 4th light is stable. Contacted TWC, They to...
DarrenM
Dec 18, 2015Sr. NETGEAR Moderator
Hello Hang94
Have you tried to do a factory reset on the modem by holding the reset button in for 10 seconds. also check if you have a cable splitter between the modem and the wall try removing that and see if it will connect. If this does not work the modem and it is still under warranty you can contact netgear phone support if the unit needs replaced
DarrenM
- Hang94Dec 18, 2015Aspirant
Reset actually made it work, but my speed supposed to be 50MB/5MB
and i cant even load the speedtest website...
