GENTEAR
Nov 26, 2023Aspirant
C3000-100nas and 3400v3 readyshare drive
192.168.0.1 I have c3000-100NAS(modem/router)that doesn't recognize my USB drive and has only 2 LAN ports. 192.168.1.1 Installed 2nd router wndr3400v3 which has 4 LANS as needed and also recogniz...
- Nov 27, 2023
I found alternative.
was able to connect to it by MAPPING drive instead of having it appear under Network.
find out what IP was given to the 2nd router by the primary router, in this case it was 192.168.0.70(NOT factory 192.168.1.1).
Map drive U: with \\192.168.0.70\USB_storage
Nov 27, 2023Guru - Experienced User
Put the WNDR router in AP mode?
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
GENTEAR
Nov 27, 2023Aspirant
Yes 2nd router is already in AP mode.
both 192.168.1.1 and Readyshare only discoverable IF connection between 1st and 2nd router is disonnected.
Maybe i could use the 2nd router as primary? Is that possible since the primary now is a Modem/Router.
