sharmar10
Oct 26, 2015Follower
C3000-100NAS Firmware Update
I have version V1.01.11. My service provider, Time Warner Cable, told me to check to see if there is an update to my firmware since the Internet seems to have gotten slower lately. When I go to 'ro...
DarrenM
Nov 10, 2015Sr. NETGEAR Moderator
b_3x
Yes netgear has to send all firmware updated to the isp then it goes threw a approval process and the isp makes some changes if needed and releases when they are ready to this is for call cable modem customer owned or rented.
DarrenM
b_3x
Nov 10, 2015Aspirant
Thank you DarrenM for the quick reply.
TWC says that they can't fix, somehow my firmware was upgraded to V2.02.26, and TWC says i need to contact Netgear as the internet is not working now.
And Netgear says it is out of warrenty, and in order to downgrade the firmware to V1.01.11, it needs to be renewed...
Do you know if the isp will be pushing a downgrade or since it is failing to connect to the interent (at very slow speed) the isp can't push a fix?
- DarrenMNov 10, 2015Sr. NETGEAR Moderator
B_3x
I don't really know what TWC will do to fix this but I can report to our engineers about a issues with the firmware. what are you seeing from the modem are all the lights coming on but no Internet connection?
DarrenM
