netspert
Jul 07, 2019Aspirant
C3000-100NAS Hard Drive not recognized
I've previously used an external IDE USB Disk housing for NAS with the C3000 and it worked OK until the drive died. I had to get a new housing due to changing to SATA drive. The C3000 would not reco...
Jul 08, 2019Guru - Experienced User
Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
Some USB 3.0 may not be backwards compatible.
- netspertJul 15, 2019Aspirant
FURRYe38 wrote:Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
I believe the old case was 2.0 (maybe not high speed 2.0); the new one is 3.0. I used the same USB cable (2.0) as I only expected 2.0 speed - and the power is separtate. It is possible that the unit is not downward compatible - I cannot get that answer from Amazon or the vendor - although I thought sownward compatibility was part of the standard. Even on the old case, I had to power-cycle the modem top get it to find the external HDD.
- FURRYe38Jul 15, 2019Guru - Experienced User
Probably the new USB 3.0 case is not compatbile with the modem.
You can't use a USB 2.0 cable on a USB 3.0 device. Has to be a 3.0 USB cable. One with the blue connector plug at each end.
