netspert
Jul 07, 2019Aspirant
C3000-100NAS Hard Drive not recognized
I've previously used an external IDE USB Disk housing for NAS with the C3000 and it worked OK until the drive died. I had to get a new housing due to changing to SATA drive. The C3000 would not reco...
Jul 08, 2019Guru - Experienced User
Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
Some USB 3.0 may not be backwards compatible.
netspert
Jul 15, 2019Aspirant
FURRYe38 wrote:Was the old USB case USB 1.0 or 2.0? Is the new USB case USB 3.0?
I believe the old case was 2.0 (maybe not high speed 2.0); the new one is 3.0. I used the same USB cable (2.0) as I only expected 2.0 speed - and the power is separtate. It is possible that the unit is not downward compatible - I cannot get that answer from Amazon or the vendor - although I thought sownward compatibility was part of the standard. Even on the old case, I had to power-cycle the modem top get it to find the external HDD.
- FURRYe38Jul 15, 2019Guru - Experienced User
Probably the new USB 3.0 case is not compatbile with the modem.
You can't use a USB 2.0 cable on a USB 3.0 device. Has to be a 3.0 USB cable. One with the blue connector plug at each end.
