pdiggs1500
Aug 20, 2015Follower
C3000-100NAS LATENCY ISSUES EVERY MINUTE
Before we start with the silly 'did you turn it on and off'' question, I just want to let you know that I'm a Network engineer with my Cisco CCNP in Routing/Switching
Anyways, I'm seeing some massive latency spikes take place, which begun in the past 1.5 months, in which I have changed NOTHING in my home network. Comcast says they are clean, and to verify this statement I'm one of their routers for this problem.
Has anyone else seen latency spike approx occur every 1 minute on their C3000-100NAS?
**WHAT I'M SEEING**
This is good...
Reply from 4.2.2.2: bytes=32 time=12ms TTL=57
Reply from 4.2.2.2: bytes=32 time=17ms TTL=57
Reply from 4.2.2.2: bytes=32 time=14ms TTL=57
Reply from 4.2.2.2: bytes=32 time=13ms TTL=57
Then every minute I get hit by one of these....
Reply from 4.2.2.2: bytes=32 time=2959ms TTL=5
then in another minute, I get hit with one of these
Reply from 4.2.2.2: bytes=32 time=1975ms TTL=5
and on and on and on and on
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello pdiggs1500
Have you tried to save your router config do a factory reset then test to see if this is happening under factory defaults if so you may need to contact netgear support could be a hardware issues. If your not getting the large spikes then reload your config and test again to see if its something in the config. Hope to hear your feedback.
DarrenM
