Billdoom
Aug 05, 2016Aspirant
C3000-100NAS periodically disconnecting from TWC
 Greetings,     I have a C3000-100NAS modem running firmware version V2.02.08 with the lovely TWC as my ISP.     For about a week now, my modem will periodically (several times a day) lose connection....
- Aug 09, 2016So apparently there was some kind of "signal problem" between TWC and the modem. The tech sent some updated signals to it and wants me to do a full power cycle and that it should be fixed.
DarrenM
Aug 08, 2016Sr. NETGEAR Moderator
Hello Billdoom
Do you have a cable splitter hooked up to the modem if so try to remove it and see if the modem stays connected sometimes those splitters can kill the signal or fail.
DarrenM
- BilldoomAug 08, 2016AspirantThere's no cable splitter. The modem is plugged directly into the wall. Over the weekend, there was another disconnect that started at Saturday 2am and the modem never recovered its connection. I returned late sunday, restarted the modem (after grabbing the logs), and the connection returned a few minutes later. Is there at least an API/setting that I can use to programmatically restart the modem when the connection is down for a few minutes? If there's no solution offered soon, I'll likely request a replacement unit as the unit is only a few months old. - DarrenMAug 09, 2016Sr. NETGEAR ModeratorHello Bildoom If you do believe its a hardware issue with the modem then I would contact support. https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic DarrenM - BilldoomAug 09, 2016AspirantIs there some way to determine what is at fault here?
