netspert's avatar
netspert
C3000-100NAS Readyshare won't recognize USB Disk
C3000-100NAS (cannot enter anything in the "model" box) is not recognizing USB drive unit, It did work with old USB 2.0 PATA unit, but not with new USB 3.0 SATA unit. Using a USB 3.0 cable, as that is...
  • netspert's avatar
    netspert
    Jul 20, 2019
    Solved one problem - only to discover another. Connecting it to the PC, I re-partioned the drive into one big Basic NTFS volume, put in a file so it wouldn't be empty, and then back on the router, and the router started recognizing that it was there.  However, I couldn't map it as a network drive, as I had the old unit.  Hmm - Windows upgrades ... I had recently moved to Win 10 Pro version 1903, without realizing that it turns off SMB ver1 in favor of SMB ver 3 - and this old model's Readyshare runs on SMB version 1.  Since the reason Microsoft made this change is for security (like blocking the "wannacry" ransomeware), I'm hesitant to turn version 1 back on (in Windows Features).  Unfortunately, I don't see upgraded firmware for this in the Downloads section.  Anybody know anything about Netgear releasing upgraded firmware?
