bbryan
Nov 18, 2019Tutor
C3000-100NAS remote access
I have three computers on my network in my business. I use a C3000-100NAS Router/Modem. I want to connect to them using Remote Desktop from other locations. They all three have static IP addresses. I can forward Port 3389 to one of them and make the connection. However since you can only forward the port to one IP I can not access the other two computers. I think Port Triggering is the way to go, but not really sure if that will allow me to access all three remotely. I use Remote Desktop App and apparently are restritcted to that particular port.
> [...] They all three have static IP addresses. [...]
LAN IP addresses? Do you mean actual static addresses (configured on
the computers themselves), or reserved dynamic addresses (configured on
(the DHCP server on) the C3000 router section)?> [...] I can forward Port 3389 to one of them [...]
True, but you can forward other ports to the other two systems (or,
as I'd advise, to all three).> [...] I use Remote Desktop App [...]
On what, another Windows system, or a Mac, or some other?
> [...] and apparently are restritcted to that particular port.
Not so. You can specify a different port number in the "PC name"
field where your connection is defined.
You might, for example, specify port-forwarding rules like the
following (all TCP):Ports
External Internal Server Address14389 3389 PC1_LAN_addr
14390 3389 PC2_LAN_addr
14391 3389 PC3_LAN_addr
On the client side, you'd specify a "PC name" like:<your_public_IP_address>:14389
<your_public_IP_address>:14390
<your_public_IP_address>:14391When exposing a well-known service like Remote Desktop to the outside
world, I would not use the default port (externally). Why make it
easier for a lazy attacker to guess the right port?I believe that it's also possible to configure the Remote Desktop
server on each system to use a non-default port, but I'd prefer to keep
things simple for intra-LAN communication, and let the router translate
the odd-ball external port numbers for external traffic.
the odd-ball external port numbers for external traffic.- bbryanTutor
Thanks for the information, was able to configure my system with your help. Solution worked.
