anatomy384
Nov 04, 2016Aspirant
C3000-100NAS vs. Macbook
I have an odd case that I can't find the answer/solution for. It seems as though my Macbook is disconnecting the wifi from my modem... Every time I'm on my Macbook Pro Retina (early '15), the wif...
anatomy384
So I tried unticking the radio box for "Disable Port Scan and DoS Protection" under Advanced > Setup > WAN Setup and so far, no disconnects, even as I left my iTunes downloading a playlist while I took a nap for a couple hours.
So enabling the port scan and DoS protection is the solution? Who knows why...
