jon_dewitt
Jul 01, 2017Aspirant
C3000-100NAS Wireless drops Wired connection works fine
Recently my wireless connection has been dropping randomly. I don't know of anything that's changed, everything connected to the wifi gets disconnected, about 6 devices normally iphones, ipad, a cou...
DarrenM
Jul 03, 2017Sr. NETGEAR Moderator
Hello jon_dewitt
Have you tried to put your wireless channel on auto so its always switching to the best channel.
DarrenM
- jon_dewittJul 03, 2017Aspirant
Yes, it was on auto after the factory reboot, and I left it there until the wireless dropped again. It's probably also worth noting that I'm out in the middle of nowhere, and there's only one other access point in range.
- pichartDec 03, 2017Aspirant
I am having the same problem. I tried switching channels, or using auto, but the problem persists. On a different thread (https://community.netgear.com/t5/Cable-Modems-Routers/Internet-connection-drops-out-but-signal-strength-remains-strong/td-p/1127604) it was suggested that one of the devices may be causing the problem, but nothing is said about what to do in case any one device is identified as the culprit. Can someone help further with this issue?
