IndianaChuck
Nov 03, 2016Follower
C3000-100NAS
We are using Tablo DVR and updated it this AM. It is wired into router as well as TV and Apple TV. We cannot access it anymore thru the Apple TV. When using the ipad and checking settings it says "requires manual configuration" "set up port mappings for TCP ports" then gives us the IP address for the Tablo
It lists Public then two numbers to the right which are red and can be modified.
Can you help?
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello IndianaChuck
I would suggest contacting support for the Tablo if it had a update then stopped working.
DarrenM
