Hglinski
Dec 26, 2016Aspirant
C3000 dropping connection
I have have had 8 wireless devices connected to my c3000 wireless router modem without problem. Added two more, occaisionally disconnect from internet . is there a limit? Is there a solution to connec...
HanabiraAsashi
Dec 30, 2016Aspirant
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out
I called my ISP and they said I wasnt getting a good signal, so they refreshed it.. it happened 2 minutes later, and apparently again an hour later.
DarrenM
Dec 30, 2016Sr. NETGEAR Moderator
Hello HanabiraAsashi
If you are getting alot of T3 and T4 timeouts then its a line issue I would have you ISP send out a Tech to check your cable lines.
DarrenM
