Hglinski
Dec 26, 2016Aspirant
C3000 dropping connection
I have have had 8 wireless devices connected to my c3000 wireless router modem without problem. Added two more, occaisionally disconnect from internet . is there a limit? Is there a solution to connec...
HanabiraAsashi
Dec 30, 2016Aspirant
Sorry about that.
| <tabindex=-1>Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Trikein
Dec 30, 2016Luminary
I am just giving my amauter opinion, but that doesn't look like a inside wiring problem. DS power level is a tiny bit low, but DS SNR is strong and all the DS power levels are within 1dB of each other. That makes me think its something going on between you and the ISP Cable Modem Termination System (CMTS) and your modem. Do the T4 errors time up with the reboot? Do you happen to live in a very congested area like a city or near a college? At this point, I would agree with the moderator that a technician is required. I would suggest requesting one that has a cable signal meter that they can hook up to the line to see if they isolate it. If you know anyone in the area, you might want to ask them if they are also having problems.
