gmarc
Jun 14, 2016Follower
c3000 extremely slow wifi
I have 150 mbps internet with xfinity, and can get those speeds on my computer when directly connected via ethernet cable. On my Mac and android over Wifi, I am getting download speeds between 1 and 10 mbps. I have not seen any firm solution on this topic, so was hoping something may have come up. Any help would be awesome, thanks!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello gmarc
I would try to change channels also try to connect 1 device at a time to the wifi and test the speed to make sure a wifi device is not bringing down the speed. If the wifi is still not working properly I would contact Netgear support.
http://www.netgear.com/support/contact.aspx?cid=gwmng
DarrenM
