BartHumphries
Oct 11, 2020Aspirant
C3000 isn't blocking website
Windows. V2.02.22 firmware with Comcast (latest). I clicked on the Advanced tab on top. I clicked Security in the left-hand navigation bar. I clicked "Block Sites" in the menu that opened. I set...
Oct 11, 2020Guru - Experienced User
After applying the change, did you reboot the modem as well?
BartHumphries
Yes and that didn't make a difference.
