jhuebner91
Oct 07, 2015Aspirant
C3000 issues
I can only connect one device at a time and I cannot acsess my router login information for some reason.
- DarrenMSr. NETGEAR Moderator
Hello jhuebner91
Have you tried to do a factory reset on the modem and try to log back into the modem?
DarrenM
- jhuebner91AspirantYes I have with the button.
jhuebner91
Here a article to find your Default gateway in case it has changed from the normal to login into the router
http://kb.netgear.com/app/answers/detail/a_id/980
also you may want to try http://www.routerlogin.net see if that works.
DarrenM
