ConnieW
May 22, 2017Aspirant
C3000 Modem/router. Upload speed is not right.
I just bought the Model C3000 N300 Wifi Cable Modem Router. My Dl speed is fine, but the upload barely reaches 1. Mbps, and sometimes less. I should be gatting at least 10 Mbps. My Isp (xfinity...
ConnieW
BTW, it's not the provider. Here is the speed after I removed the new modem and put the old one back.
- DarrenMMay 24, 2017Sr. NETGEAR Moderator
Hello ConnieW
I would suggest contacting support they will be able to troubleshoot the issue and replace the modem if needed.
http://www.netgear.com/support/contact.aspx
DarrenM
- ConnieWMay 25, 2017Aspirant
I returned the C3000 and got the C3700 and had the same problem. It eventually started working right after I had asked for a tech visit. I ended up canceling that appt. I have no idea why it started working right during that evening. I had already done everything I could on my end and my ISP had done all they could online. Thanks for your reply.
