3DPiper
Apr 18, 2015Aspirant
C3000 Modem/Router
Our Comcast modem went out, so I picked up this modem/router at WalMart for $100.. The modem I had was an Ubee D3.0, the router I used with it was a Netgear WNDR4000..    Will this be comparable to wh...
sabretooth
Apr 30, 2015Apprentice
Well that is a gateway device, which are terrible for wireless connection.  You should buy your on modem only like the Motorola SB6183 and add your own separate router for optimal results.
