3DPiper
Apr 18, 2015Aspirant
C3000 Modem/Router
Our Comcast modem went out, so I picked up this modem/router at WalMart for $100.. The modem I had was an Ubee D3.0, the router I used with it was a Netgear WNDR4000..    Will this be comparable to wh...
lurzan
Apr 30, 2015Novice
You have got a Gateway which works as MODEM as well as the router. It has the wireless built in but still you can make it work as modem alone by changing the operational mode to just MODEM and use your WNDR4000 as wireless router
Find the specification with the link: http://www.netgear.com/home/products/networking/cable-modems-routers/C3000.aspx#tab-techspecs
To disable router mode to make it only a modem:
- open router gui using www.routerlogin.net or 192.168.0.1
- Go to advance page
- click to Administration and then click to Router Mode
- Select No and click to Apply
