sika
Apr 05, 2017Aspirant
C3000-Port forwarding issues
I have setup port forwarding on the above mentioned router, however the port is still closed when its checked using online tools. I have done lots of reading on port forward but still can't seem to s...
sika
I was able to get the port open simply by adding the internal IP to the DMZ.
- sikaApr 05, 2017Aspirant
I don't believe this is the right way of doing it, that's assigning the application/service as DMZ server. It doesn't feel right. Any other ways to fix these issues?
- DarrenMApr 12, 2017Sr. NETGEAR Moderator
Hello Sika
What ports are you trying to open sometimes certain ones are blocked by the Isp others are reserved on the router for functions.
DarrenM
- sikaApr 18, 2017Aspirant
hello DarrenM,
For starters thankyou for your response. I have tried several ports, 80, 443, and 350 and all of them are closed.
