HokieCharles
Jan 31, 2017Aspirant
C3000 Speed is slow for LAN
I just upgraded my Comcast account to 150Mbps download speed. The highest any speed test shows is 94Mbps. Comcast came and replaced the cable from the box to the building and we tested the interior c...
- Feb 03, 2017
I discovered the culprit—my laptop has a Fast ethernet controller rather than a Gigabit controller, so it won't get above 100Mbps. Off to buy a Gigabit USB ethernet adapter and see if that will work.
DarrenM
Feb 03, 2017Sr. NETGEAR Moderator
Hello HokieCharles
Have you tried speed tests to different servers because having 150Mbps does not mean you get that all the time its up to 150Mbps.
DarrenM
