spamsucks
Mar 03, 2017Aspirant
c3000 Super slow speeds comcast.
So I changed to this device after my cable modem was dropping so often, and comcast was quick to get it running with no interaction at all... just the3 automated things. With this new modem in place,...
- Mar 06, 2017
Hello Spamsucks
Have you checked with the cable company that the modem is provisioned correctly because it sounds like the c3000 is on a separate plan if you can still plug in your other modem and its working.
DarrenM
DarrenM
Mar 06, 2017Sr. NETGEAR Moderator
Hello Spamsucks
DarrenM
