skywalker993
Sep 03, 2015Follower
C3000 Terrible Wifi... "unstable connection" message on any wireless device.
Wired connections are fine and speedy. Wireless connections (even just 1 device at a time) are incredibly slow if ever able to connect. Most phones and laptops show a "network is unstable" or "ready ...
cooljb96
Oct 15, 2015Aspirant
And before you ask, I have changed the channel - I used the genie interface to see which channels are not being used and tried them. No improvement. And the issue occurs on any device I connect using WiFi. This firmware update is definitely the culprit. WiFi performance was great before the update.
VWW
Jan 29, 2016Aspirant
Same problem here with Comcast Blast Pro. Rebooted, changed channel, checked firmware, etc.
