skywalker993
Sep 03, 2015Follower
C3000 Terrible Wifi... "unstable connection" message on any wireless device.
Wired connections are fine and speedy. Wireless connections (even just 1 device at a time) are incredibly slow if ever able to connect. Most phones and laptops show a "network is unstable" or "ready ...
DarrenM
Oct 09, 2015Sr. NETGEAR Moderator
Hello skywalker933
have you tried changing the wireless channel on the router to see if you are getting better speeds. also have you tried a factory reset and set the router up again and test it? and like you said its still under warranty you can contact netgear support if its defective and have it swapped.
DarrenM
