stomptoblock
May 20, 2017Aspirant
C3000 to C3700 Wireless AP HELP!!!
Hi, I have two gateway routers, a C3700 as my main. i have crapy wifi in some parts of my house and i have another C3000. I would like to turn the C3000 into a Wireless AP but when i go to the Wirele...
stomptoblock
But it says in the settings of the router that you can wireless connect it to anothet router so that the one connecting to another router can be used as a wireless ap
TheEther
May 21, 2017Guru
It would be unusual for the C3000 to have this capability. Netgear usually does not provide it in their routers.
stomptoblock wrote:
Also the router doesn't have a Ethernet in port on it...
Are you talking about the C3700? It has two Ethernet ports.
stomptoblock wrote:
Can a range extender be used to wireless connect to my main router if so, can i use my current setup for this?
Yes you can use a range extender to wirelessly connect to your main router. It won't, however, be as fast as a wired Access Point.
