stomptoblock
May 20, 2017Aspirant
C3000 to C3700 Wireless AP HELP!!!
Hi, I have two gateway routers, a C3700 as my main. i have crapy wifi in some parts of my house and i have another C3000. I would like to turn the C3000 into a Wireless AP but when i go to the Wirele...
stomptoblock
May 21, 2017Aspirant
It has 2 out no in
- TheEtherMay 21, 2017Guru
If you want to set up the C3000 as a wired Access Point, then you can use either Ethernet port.
