JohnInWoodside's avatar
Nov 14, 2015
C3000 with hung DHCP process?
I have a Netgear C3000 cable modem/gateway, connected to Comcast.  Multiple Macs in the house, with both WiFi and Ethernet access to the gateway.
Everything generally works, but every few days one of our computers cannot get Internet access;  if you examine Preferences/Network it shows that the machine has no IP address, and can't seem to get one.
This typically happens when a) a machine is awakend from sleep, or b) someone brings a new laptop to the house.
It is usually the case that another machine which has been running (i.e., has an IP address) can continue to access the Internet during this time.
So it appears that the basic router function is running, but it smells like a hung DHCP process in the Netgear gateway router.  Indeed, if we re-boot the box, the computer then gets an address and can then access the Internet.
Has anyone seen this before?
Suggestions on how to fix it?  [Other then having to reboot all the time......]
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Johninwoodside
    Have you tried to do Address reservation on your devices to see if it will save that IP and will not disconnect.
    DarrenM
    • JohnInWoodside's avatar
      JohnInWoodside
      Thanks for the suggestion, and I did think of it.
      a.  A reserved IP address for each machine might help with devices that are regularly in the house -- but requires that I keep track of all the address assignments (and rather defeats the purpose of having DHCP to begin with!).
      b.  More importantly, that will NOT help with the case where my kids' friends bring over a laptop or phone with WiFi, and can't get an IP address -- "Dad, the Internet's broken again!  Do I have to go re-boot it again?! Why don't you go buy a different router?!"  It doesn't happen every time, but when it does a re-boot of the router seems to fix the problem -- but that's a nuisance (and supports the idea that DHCP is getting hung).
      [Netgear has a terrible reputation for bad customer support, and I am now beginning to understand why people complain.  Do any Netgear engineers actually monitor these boards?]
      • vkdelta's avatar
        vkdelta
        NETGEAR Employee Retired
        JohnInWoodside
        what FW are you running? (I would assume it is V2.02.06)
        Did you have this problem always or it recently?
        Is there anyway, you can share wireshark capture when the DHCP process is failing on your C3000?
        (wireshark capture on your PC when it does not get an IP, We would like to see if the device is NOT sending DHCP OFFER or DHCP ACK)
