JohnInWoodside
Nov 14, 2015Aspirant
C3000 with hung DHCP process?
I have a Netgear C3000 cable modem/gateway, connected to Comcast. Multiple Macs in the house, with both WiFi and Ethernet access to the gateway. Everything generally works, but every few days one o...
vkdelta
Nov 21, 2015NETGEAR Employee Retired
No problem. I will be here.
Let me know if you see it again. we would like to know more details as well as it will help everyone. and THANK YOU for trying to replicate and willing to work with us.
JohnInWoodside
Nov 21, 2015Aspirant
Well, this morning when I woke my desktop iMac from sleep it could not connect to the Internet -- and it was the machine on which I had loaded WireShark (!).
[One note: looking at Preferences/Network the machine seemed to have a long IP-V6 address, but no IP-V4 address, no DNS field, nor anything else.]
Sadly, I had not yet practiced how to run WireShark with capture filters, but I did this:
a. Ran for a little bit, to get a "pre-restart" sample, and saved the file.
b. Started a second run, went downstairs, re-booted the router, waited until the machine could fully access the Internet (first gets address, takes longer to get Comcast DNS fields), stopped WireShark, and saved a second (longer) file.
What is the best way to send these 2 files to you?
Thanks for the ongoing help.
John
- vkdeltaNov 21, 2015NETGEAR Employee Retired
Hi John,
See if you can send me private message with attachements.
If not, just upload them on a dropbox public and give me a link to download.
Let me know if either of those work for you.
thanks!
