jj12's avatar
jj12
Follower
Aug 10, 2018
C3000 Won't turn on
My router was working fine, then last week it stopped working. Now it won't turn on, i switched the power cord to see if it was broken, and with the new one it turned on and all the lights flashed for a few seconds and then it just stopped. Now it won't do anything at all. Is there any way to fix this?
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    You could try to hold the reset button on the back for 30 seconds if it still has no life you may need to contact support if the modem is still under warranty.
    DarrenM
