fiddletwix
Jul 17, 2016Aspirant
C3000Dv2 won't bridge
I recently came home to discover that my Cable Modem was no longer in bridge mode and had NAT enabled. I went to change the setting by unchecking the "Enable NAT" box but the change won't stick. The...
TheEther
Jul 18, 2016Guru
Did TWC supply you with the modem? If so, check with TWC. Maybe, just maybe, they have locked out bridge mode.
