fiddletwix
Jul 17, 2016Aspirant
C3000Dv2 won't bridge
I recently came home to discover that my Cable Modem was no longer in bridge mode and had NAT enabled. I went to change the setting by unchecking the "Enable NAT" box but the change won't stick. The...
fiddletwix
Jul 18, 2016Aspirant
No, this is my own device but this did happen when they also made some change that forced an IP change. I had the same IP for about a year and then it changed along with bridged mode. Is there anyway to verify that config option is locked out? They have in the past acted like this is their modem and factory reset it before so I can believe they made the change.
- TheEtherJul 19, 2016Guru
I don't know of any other way to verify other than the GUI itself. Can you try doing a factory reset?
