kevin862551's avatar
kevin862551
Follower
Apr 23, 2019
C3600 My SSID does not show up and i can not connect
I randomly lost connection to my wifi. I can now no longer see my wifi domain (Netgear 15) pop up in the (wifi:looking for networks).I have accessed the router settings while being connected through ethernet and have checked to see if the SSID are all enabled(which they are). I have contacted cox (my ISP) they told me everything was fine on their end. I did a modem reset, nothing changed. I did a factory reset and nothing changed.
1 Reply
  • FURRYe38's avatar
    Log into the modem and change the wifi SSID name to something different. Try 862551, save and apply. See if you see the new SSID name on any wifi devices. If not, you may need to get the C3600 replaced.
