Saumitra's avatar
Saumitra
Follower
Dec 02, 2016
C3700 – N600, Cant connect to 5GHZ
Hi,
I am able to connect with 2.4 GHz with password. But the same password doesnt work for 5 GHz.
Please help me.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Saumitra
    They can be set as separate passwords while connected to the wifi go to 192.168.0.1 login with admin/password then go to wireless settings and you should be able to set the password.
    DarrenM
