mrjohncool35
Aug 01, 2015Tutor
C3700-100NAS - Connection issues
Have had the modem/router in one for awhile but it seems glitchy. Firmware Version V1.01.11 I have this current one as a replacement but it seems it may be worse or just as bad as the first ...
ElaineM
Aug 04, 2015NETGEAR Employee Retired
Hi mrjohncool35,
Looks like after replacing the unit, the concern still exists. When did the disconnection start? How many times will it reboot? Do you happen to run a particular application then it will reboot? Or this happens randomly? Did you try using a different modem to verify if it will give you the same problem? Perhaps you could try a test modem from your ISP. Let us know what happens.
- mrjohncool35Aug 05, 2015Tutor
I am unsure how many times a Day it does reboot but i'm concerned with the fact that the router reboots when i open up chrome or another browser and go to access the router with my computer. That right there is a Bug/Flaw in your software causing the hardware to be faulty as well. My devices are 3 Cell phones - Andriod, a Roko Stick, 3 Laptops, 1 Desktop wireless and 1 directly plugged in and a Magic Jack Plus Plugged in.
I create my own Router ID and Pass Phrase for it so it is more secure than most routers.
My concern is the router ID is the issue or I have yet found another Faulty router.
Router ID is similar to: AaaaaAAaaaa!
Router Pass Phrase is: Aaaa 0000 Aaaaa Aaaaa Aaaa!
Of course those are not exactly 100% how it is setup but a good example how I have set my router up to be more secure vs using default settings.
I am unsure if any of the devices listed above would cause a problem. All my computers are Windows 7 systems.
Please advise as to if there is a Firmware update or something else that may be causing this issue. My cable company has stated there was some static or something in my line but it has since then been cleaned up and my Coax is good as the TV's work perfectly fine.
- ElaineMAug 05, 2015NETGEAR Employee Retired
mrjohncool35 All firmware push will be done by the ISP. There is no way to upgrade the firmware manually for your device. Since you have the latest firmware, kindly PM me a copy of your configuration file, logs, event logs and cable connection page for analysis.
- mrjohncool35Aug 10, 2015Tutor
Here is a copy of my logs:
Description Count Last Occurrence Target Source
[LAN access from remote] from 103.3.127.204:19412 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 103.3.127.204:19412
[LAN access from remote] from 66.46.171.227:11841 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 66.46.171.227:11841
[LAN access from remote] from 61.226.246.122:28736 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 61.226.246.122:28736
[LAN access from remote] from 78.104.250.129:38227 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 78.104.250.129:38227
[LAN access from remote] from 35.21.69.162:35276 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 35.21.69.162:35276
[LAN access from remote] from 123.72.136.139:32029 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 123.72.136.139:32029
[LAN access from remote] from 74.54.102.110:63706 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 74.54.102.110:63706
[LAN access from remote] from 118.53.40.210:4926 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 118.53.40.210:4926
[LAN access from remote] from 106.84.34.140:62772 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 106.84.34.140:62772
[LAN access from remote] from 97.235.108.174:11910 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 97.235.108.174:11910
[LAN access from remote] from 122.232.86.243:19141 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 122.232.86.243:19141
[LAN access from remote] from 110.208.160.24:31674 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 110.208.160.24:31674
[LAN access from remote] from 106.243.246.134:51822 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 106.243.246.134:51822
[LAN access from remote] from 51.171.47.113:38087 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 51.171.47.113:38087
[LAN access from remote] from 40.209.205.16:7348 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 40.209.205.16:7348
[LAN access from remote] from 21.82.111.11:38831 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 21.82.111.11:38831
[LAN access from remote] from 107.192.97.5:13959 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 107.192.97.5:13959
[LAN access from remote] from 8.159.109.183:31989 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 8.159.109.183:31989
[LAN access from remote] from 26.242.85.87:35131 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 26.242.85.87:35131
[LAN access from remote] from 61.116.97.226:56010 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 61.116.97.226:56010
[LAN access from remote] from 31.70.90.193:38733 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 31.70.90.193:38733
[LAN access from remote] from 54.220.111.138:56130 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 54.220.111.138:56130
[LAN access from remote] from 1.234.226.234:58558 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 1.234.226.234:58558
[LAN access from remote] from 60.174.18.189:35353 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 60.174.18.189:35353
[LAN access from remote] from 7.95.36.244:12722 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 7.95.36.244:12722
[LAN access from remote] from 22.234.169.53:54537 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 22.234.169.53:54537
[LAN access from remote] from 94.138.161.165:23739 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 94.138.161.165:23739
[LAN access from remote] from 121.121.104.234:23006 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 121.121.104.234:23006
[LAN access from remote] from 81.80.88.61:63709 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 81.80.88.61:63709
[LAN access from remote] from 88.118.250.2:43248 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 88.118.250.2:43248
[LAN access from remote] from 87.62.211.112:32750 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 87.62.211.112:32750
[LAN access from remote] from 91.9.165.153:22957 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 91.9.165.153:22957
[LAN access from remote] from 5.155.184.162:49624 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 5.155.184.162:49624
[LAN access from remote] from 115.155.152.161:32217 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 115.155.152.161:32217
[LAN access from remote] from 5.145.47.188:14558 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 5.145.47.188:14558
[LAN access from remote] from 71.75.165.197:12893 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 71.75.165.197:12893
[LAN access from remote] from 46.49.232.94:17090 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 46.49.232.94:17090
[LAN access from remote] from 45.61.232.21:16529 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 45.61.232.21:16529
[LAN access from remote] from 42.90.221.84:12298 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 42.90.221.84:12298
[LAN access from remote] from 63.57.83.30:53136 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 63.57.83.30:53136
[LAN access from remote] from 61.130.232.177:25015 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 61.130.232.177:25015
[LAN access from remote] from 98.193.143.42:21166 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 98.193.143.42:21166
[LAN access from remote] from 114.150.207.246:45860 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 114.150.207.246:45860
[LAN access from remote] from 87.220.200.180:30318 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 87.220.200.180:30318
[LAN access from remote] from 52.102.168.252:4042 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 52.102.168.252:4042
[LAN access from remote] from 104.174.73.163:6401 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 104.174.73.163:6401
[LAN access from remote] from 98.157.59.166:65248 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 98.157.59.166:65248
[LAN access from remote] from 27.6.183.98:60270 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 27.6.183.98:60270
[LAN access from remote] from 5.33.126.241:34611 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 5.33.126.241:34611
[LAN access from remote] from 38.221.231.28:13016 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 38.221.231.28:13016
[LAN access from remote] from 119.233.101.166:21370 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 119.233.101.166:21370
[LAN access from remote] from 18.5.53.224:22506 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 18.5.53.224:22506
[LAN access from remote] from 104.198.146.9:24983 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 104.198.146.9:24983
[LAN access from remote] from 2.182.29.127:8427 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 2.182.29.127:8427
[LAN access from remote] from 4.56.174.45:46237 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 4.56.174.45:46237
[LAN access from remote] from 59.67.28.163:37161 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 59.67.28.163:37161
[LAN access from remote] from 40.19.7.37:21835 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 40.19.7.37:21835
[LAN access from remote] from 58.199.3.198:30548 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 58.199.3.198:30548
[LAN access from remote] from 113.151.65.9:8761 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 113.151.65.9:8761
[LAN access from remote] from 18.126.141.149:45201 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 18.126.141.149:45201
[LAN access from remote] from 205.134.243.222:51860 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 205.134.243.222:51860
[LAN access from remote] from 205.134.243.222:41734 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 205.134.243.222:41734
[LAN access from remote] from 65.172.148.244:5710 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 65.172.148.244:5710
[LAN access from remote] from 111.131.103.191:17607 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 111.131.103.191:17607
[LAN access from remote] from 43.7.32.225:29935 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 43.7.32.225:29935
[LAN access from remote] from 103.151.80.42:7514 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 103.151.80.42:7514
[LAN access from remote] from 35.6.78.81:37469 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 35.6.78.81:37469
[LAN access from remote] from 83.110.62.135:58211 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 83.110.62.135:58211
[LAN access from remote] from 62.14.214.73:20583 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 62.14.214.73:20583
[LAN access from remote] from 100.180.72.196:4142 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 100.180.72.196:4142
[LAN access from remote] from 124.53.89.10:20342 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 124.53.89.10:20342
[LAN access from remote] from 8.175.140.207:39981 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 8.175.140.207:39981
[LAN access from remote] from 107.130.253.68:53834 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 107.130.253.68:53834
[LAN access from remote] from 85.39.241.207:39455 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 85.39.241.207:39455
[LAN access from remote] from 70.91.26.93:42259 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 70.91.26.93:42259
[LAN access from remote] from 52.129.27.220:33502 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 52.129.27.220:33502
[LAN access from remote] from 72.63.184.42:18090 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 72.63.184.42:18090
[LAN access from remote] from 62.29.27.19:38221 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 62.29.27.19:38221
[LAN access from remote] from 80.136.219.98:31348 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 80.136.219.98:31348
[LAN access from remote] from 211.234.100.117:41842 to 192.168.0.16:5900 1 Mon Aug 10 21:36:55 2015 192.168.0.16:5900 211.234.100.117:41842
[LAN access from remote] from 100.234.115.211:15273 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 100.234.115.211:15273
[LAN access from remote] from 83.142.78.187:62423 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 83.142.78.187:62423
[LAN access from remote] from 97.243.36.10:58864 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 97.243.36.10:58864
[LAN access from remote] from 115.166.10.234:61494 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 115.166.10.234:61494
[LAN access from remote] from 62.38.17.160:35820 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 62.38.17.160:35820
[LAN access from remote] from 66.240.44.109:45133 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 66.240.44.109:45133
[LAN access from remote] from 92.233.43.195:58261 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 92.233.43.195:58261
[LAN access from remote] from 96.55.65.67:65457 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 96.55.65.67:65457
[LAN access from remote] from 124.112.168.76:40750 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 124.112.168.76:40750
[LAN access from remote] from 35.119.139.150:53380 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 35.119.139.150:53380
[LAN access from remote] from 217.160.206.182:56040 to 192.168.0.16:5900 1 Mon Aug 10 21:36:54 2015 192.168.0.16:5900 217.160.206.182:56040
[LAN access from remote] from 75.215.194.86:22534 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 75.215.194.86:22534
[LAN access from remote] from 92.88.102.211:7557 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 92.88.102.211:7557
[admin login] from source 192.168.0.12 1 Mon Aug 10 21:36:53 2015 0.0.0.0:0 192.168.0.12:0
[LAN access from remote] from 36.55.176.4:63090 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 36.55.176.4:63090
[LAN access from remote] from 111.165.117.53:21121 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 111.165.117.53:21121
[LAN access from remote] from 17.86.30.28:16072 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 17.86.30.28:16072
[LAN access from remote] from 23.56.245.237:8799 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 23.56.245.237:8799
[LAN access from remote] from 37.173.16.22:22896 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 37.173.16.22:22896
[LAN access from remote] from 99.107.57.86:65068 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 99.107.57.86:65068
[LAN access from remote] from 88.75.92.158:2870 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 88.75.92.158:2870
[LAN access from remote] from 76.254.52.168:52388 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 76.254.52.168:52388
[LAN access from remote] from 107.213.130.141:22585 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 107.213.130.141:22585
[LAN access from remote] from 31.53.87.213:37951 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 31.53.87.213:37951
[LAN access from remote] from 29.224.18.7:19399 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 29.224.18.7:19399
[LAN access from remote] from 74.25.41.157:48079 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 74.25.41.157:48079
[LAN access from remote] from 44.109.134.80:56618 to 192.168.0.16:53 1 Mon Aug 10 21:36:51 2015 192.168.0.16:53 44.109.134.80:56618
[LAN access from remote] from 32.26.211.95:4501 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 32.26.211.95:4501
[LAN access from remote] from 15.247.6.136:9334 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 15.247.6.136:9334
[LAN access from remote] from 96.250.213.221:38355 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 96.250.213.221:38355
[LAN access from remote] from 70.61.46.152:47378 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 70.61.46.152:47378
[LAN access from remote] from 126.59.79.69:18877 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 126.59.79.69:18877
[LAN access from remote] from 6.98.187.213:50841 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 6.98.187.213:50841
[LAN access from remote] from 97.225.80.105:4653 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 97.225.80.105:4653
[LAN access from remote] from 35.109.56.2:31964 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 35.109.56.2:31964
[LAN access from remote] from 44.148.166.243:65051 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 44.148.166.243:65051
[LAN access from remote] from 74.228.165.90:14628 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 74.228.165.90:14628
[LAN access from remote] from 29.144.81.107:35467 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 29.144.81.107:35467
[LAN access from remote] from 100.51.208.180:38684 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 100.51.208.180:38684
[LAN access from remote] from 74.191.223.31:29343 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 74.191.223.31:29343
[LAN access from remote] from 92.41.74.132:216 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 92.41.74.132:216
[LAN access from remote] from 50.184.181.124:6382 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 50.184.181.124:6382
[LAN access from remote] from 128.125.98.102:24930 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 128.125.98.102:24930
[LAN access from remote] from 111.216.220.52:47590 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 111.216.220.52:47590
[LAN access from remote] from 38.132.254.67:18765 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 38.132.254.67:18765
[LAN access from remote] from 54.121.55.121:41579 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 54.121.55.121:41579
[LAN access from remote] from 57.200.51.40:42168 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 57.200.51.40:42168
[LAN access from remote] from 56.56.105.17:55169 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 56.56.105.17:55169
[LAN access from remote] from 90.190.123.48:11950 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 90.190.123.48:11950
[LAN access from remote] from 24.138.57.197:26841 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 24.138.57.197:26841
[LAN access from remote] from 62.90.223.93:23059 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 62.90.223.93:23059
[LAN access from remote] from 4.59.147.146:39432 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 4.59.147.146:39432
[LAN access from remote] from 12.251.254.197:5821 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 12.251.254.197:5821
- mrjohncool35Aug 09, 2015Tutor
The problem is intermetent. Plus this problem with me logging onto the Router with the IP address seems to be constantly happening when i feel there is a slow connection and i want to manually reboot the router from a browser the modem/router reboots itself when logging into it. That shouldn't Ever happen. I feel I have a Faulty Router and should be upgraded to a newer version or something. This router seems to have Faults that are not mine. I have used routers and modems since 1998 as a IT Specialist and this one has faulty software and possibly hardware. There is no way this modem should give me this much trouble compared to a modem and router separate. I have given you a Name of a router that i use but not the exact and a Pass Phrase as well but yet you don't tell me whether there is a flaw in using that Pass phrase or Router name that may cause this issue. I tried a Modem and Router and The reboot issue does NOT happen as it does with this one so this router seems to be faulty as either a hardware issue or software/firmware. I would suggest i get a newer or better model.
- ElaineMAug 10, 2015NETGEAR Employee Retired
mrjohncool35 There shouldn't be any issue in using that passphrase or router name you provided. Based from your description it could be a faulty hardware or could also be a software. However, for us to understand the real cause of it we would need the information asked previously.
Logs:
[LAN access from remote] from 118.32.164.123:36541 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 118.32.164.123:36541
[LAN access from remote] from 45.92.105.120:49712 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 45.92.105.120:49712
[LAN access from remote] from 48.68.248.228:22382 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 48.68.248.228:22382
[LAN access from remote] from 7.41.5.180:4614 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 7.41.5.180:4614
[LAN access from remote] from 9.30.139.198:39938 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 9.30.139.198:39938
[LAN access from remote] from 95.160.171.68:26758 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 95.160.171.68:26758
[LAN access from remote] from 30.75.41.9:25503 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 30.75.41.9:25503
[LAN access from remote] from 110.185.24.130:62452 to 192.168.0.16:53 1 Mon Aug 10 21:36:48 2015 192.168.0.16:53 110.185.24.130:62452
[LAN access from remote] from 24.54.215.210:62765 to 192.168.0.16:61000 1 Mon Aug 10 21:36:47 2015 192.168.0.16:61000 24.54.215.210:62765
[LAN access from remote] from 69.130.179.64:15430 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 69.130.179.64:15430
[LAN access from remote] from 97.255.12.203:52937 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 97.255.12.203:52937
[LAN access from remote] from 89.168.249.38:43640 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 89.168.249.38:43640
[LAN access from remote] from 118.191.126.44:27052 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 118.191.126.44:27052
[LAN access from remote] from 42.156.134.91:55699 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 42.156.134.91:55699
[LAN access from remote] from 61.121.69.38:48664 to 192.168.0.16:53 1 Mon Aug 10 21:36:47 2015 192.168.0.16:53 61.121.69.38:48664
[LAN access from remote] from 49.104.87.4:47060 to 192.168.0.16:53 1 Mon Aug 10 21:36:46 2015 192.168.0.16:53 49.104.87.4:47060
[LAN access from remote] from 73.240.135.6:6376 to 192.168.0.16:53 1 Mon Aug 10 21:36:46 2015 192.168.0.16:53 73.240.135.6:6376
[LAN access from remote] from 97.158.58.172:64488 to 192.168.0.16:53 1 Mon Aug 10 21:36:46 2015 192.168.0.16:53 97.158.58.172:64488
[LAN access from remote] from 89.246.222.190:37036 to 192.168.0.16:53 1 Mon Aug 10 21:36:46 2015 192.168.0.16:53 89.246.222.190:37036
[LAN access from remote] from 89.243.129.231:13263 to 192.168.0.16:53 1 Mon Aug 10 21:36:46 2015 192.168.0.16:53 89.243.129.231:13263
[LAN access from remote] from 38.230.189.236:2490 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 38.230.189.236:2490
[LAN access from remote] from 81.38.191.133:24531 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 81.38.191.133:24531
[LAN access from remote] from 53.44.142.255:63319 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 53.44.142.255:63319
[LAN access from remote] from 89.17.46.118:56984 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 89.17.46.118:56984
[LAN access from remote] from 116.38.214.55:48261 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 116.38.214.55:48261
[LAN access from remote] from 5.48.105.7:29031 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 5.48.105.7:29031
[LAN access from remote] from 80.217.114.34:4566 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 80.217.114.34:4566
[LAN access from remote] from 61.108.63.61:47125 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 61.108.63.61:47125
[LAN access from remote] from 30.60.29.6:22398 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 30.60.29.6:22398
[LAN access from remote] from 40.12.89.167:42943 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 40.12.89.167:42943
[LAN access from remote] from 80.242.159.50:16152 to 192.168.0.16:53 1 Mon Aug 10 21:36:45 2015 192.168.0.16:53 80.242.159.50:16152
[LAN access from remote] from 99.40.219.75:40861 to 192.168.0.16:53 1 Mon Aug 10 21:36:44 2015 192.168.0.16:53 99.40.219.75:40861
[LAN access from remote] from 67.36.46.3:45643 to 192.168.0.16:53 1 Mon Aug 10 21:36:44 2015 192.168.0.16:53 67.36.46.3:45643
[LAN access from remote] from 2.181.178.228:46670 to 192.168.0.16:53 1 Mon Aug 10 21:36:44 2015 192.168.0.16:53 2.181.178.228:46670
[LAN access from remote] from 52.164.54.212:40476 to 192.168.0.16:53 1 Mon Aug 10 21:36:44 2015 192.168.0.16:53 52.164.54.212:40476
[LAN access from remote] from 21.29.210.183:64241 to 192.168.0.16:53 1 Mon Aug 10 21:36:44 2015 192.168.0.16:53 21.29.210.183:64241
[LAN access from remote] from 38.1.241.183:15291 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 38.1.241.183:15291
[LAN access from remote] from 54.25.178.255:7475 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 54.25.178.255:7475
[LAN access from remote] from 117.222.186.47:41965 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 117.222.186.47:41965
[LAN access from remote] from 84.77.51.244:55950 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 84.77.51.244:55950
[LAN access from remote] from 65.159.179.43:13419 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 65.159.179.43:13419
[LAN access from remote] from 121.24.154.236:35614 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 121.24.154.236:35614
[LAN access from remote] from 121.178.145.198:33580 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 121.178.145.198:33580
[LAN access from remote] from 83.205.233.46:36554 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 83.205.233.46:36554
[LAN access from remote] from 18.115.201.7:60397 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 18.115.201.7:60397
[LAN access from remote] from 114.245.47.21:4607 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 114.245.47.21:4607
[LAN access from remote] from 41.201.121.95:51953 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 41.201.121.95:51953
[LAN access from remote] from 102.112.137.18:21492 to 192.168.0.16:53 1 Mon Aug 10 21:36:43 2015 192.168.0.16:53 102.112.137.18:21492
[LAN access from remote] from 53.15.179.110:7054 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 53.15.179.110:7054
[LAN access from remote] from 15.150.32.190:15850 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 15.150.32.190:15850
[LAN access from remote] from 107.61.145.243:26223 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 107.61.145.243:26223
[LAN access from remote] from 54.30.57.237:42025 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 54.30.57.237:42025
[LAN access from remote] from 41.80.162.187:62299 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 41.80.162.187:62299
[LAN access from remote] from 80.147.59.129:55975 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 80.147.59.129:55975
[LAN access from remote] from 63.182.206.183:19493 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 63.182.206.183:19493
[LAN access from remote] from 24.54.215.210:62765 to 192.168.0.16:61000 1 Mon Aug 10 21:36:42 2015 192.168.0.16:61000 24.54.215.210:62765
[LAN access from remote] from 80.54.160.254:16236 to 192.168.0.16:53 1 Mon Aug 10 21:36:42 2015 192.168.0.16:53 80.54.160.254:16236
[LAN access from remote] from 88.194.118.77:9683 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 88.194.118.77:9683
[LAN access from remote] from 71.132.7.215:38111 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 71.132.7.215:38111
[LAN access from remote] from 2.228.224.137:58449 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 2.228.224.137:58449
[LAN access from remote] from 62.36.11.114:34234 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 62.36.11.114:34234
[LAN access from remote] from 15.87.62.132:23346 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 15.87.62.132:23346
[LAN access from remote] from 111.184.224.226:48724 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 111.184.224.226:48724
[LAN access from remote] from 122.47.1.132:62434 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 122.47.1.132:62434
[LAN access from remote] from 124.113.125.206:29874 to 192.168.0.16:53 1 Mon Aug 10 21:36:41 2015 192.168.0.16:53 124.113.125.206:29874
[LAN access from remote] from 1.203.62.211:16489 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 1.203.62.211:16489
[LAN access from remote] from 25.77.28.57:19667 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 25.77.28.57:19667
[LAN access from remote] from 39.158.27.74:26758 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 39.158.27.74:26758
[LAN access from remote] from 80.227.191.240:24504 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 80.227.191.240:24504
[LAN access from remote] from 24.54.215.210:62703 to 192.168.0.16:61002 1 Mon Aug 10 21:36:40 2015 192.168.0.16:61002 24.54.215.210:62703
[LAN access from remote] from 119.123.21.61:565 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 119.123.21.61:565
[LAN access from remote] from 29.32.247.198:12296 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 29.32.247.198:12296
[LAN access from remote] from 50.84.33.143:33847 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 50.84.33.143:33847
[LAN access from remote] from 44.14.62.134:38050 to 192.168.0.16:53 1 Mon Aug 10 21:36:40 2015 192.168.0.16:53 44.14.62.134:38050
[LAN access from remote] from 96.127.10.70:51524 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 96.127.10.70:51524
[LAN access from remote] from 128.219.167.51:42731 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 128.219.167.51:42731
[LAN access from remote] from 48.82.159.242:65174 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 48.82.159.242:65174
[LAN access from remote] from 80.246.186.151:23173 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 80.246.186.151:23173
[LAN access from remote] from 124.146.32.232:6158 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 124.146.32.232:6158
[LAN access from remote] from 84.79.224.90:34554 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 84.79.224.90:34554
[LAN access from remote] from 195.3.144.87:58367 to 192.168.0.16:5900 1 Mon Aug 10 21:36:39 2015 192.168.0.16:5900 195.3.144.87:58367
[LAN access from remote] from 27.243.13.154:17280 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 27.243.13.154:17280
[LAN access from remote] from 120.23.183.52:42340 to 192.168.0.16:53 1 Mon Aug 10 21:36:39 2015 192.168.0.16:53 120.23.183.52:42340
[LAN access from remote] from 24.54.215.210:62765 to 192.168.0.16:61000 1 Mon Aug 10 21:36:38 2015 192.168.0.16:61000 24.54.215.210:62765
[LAN access from remote] from 106.47.184.37:35461 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 106.47.184.37:35461
[LAN access from remote] from 17.58.66.145:25349 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 17.58.66.145:25349
[LAN access from remote] from 98.177.104.115:11223 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 98.177.104.115:11223
[LAN access from remote] from 13.187.190.144:55302 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 13.187.190.144:55302
[LAN access from remote] from 37.190.180.87:64979 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 37.190.180.87:64979
[LAN access from remote] from 38.3.8.50:21048 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 38.3.8.50:21048
[LAN access from remote] from 108.163.243.64:51848 to 192.168.0.16:53 1 Mon Aug 10 21:36:38 2015 192.168.0.16:53 108.163.243.64:51848
[LAN access from remote] from 118.16.171.171:38349 to 192.168.0.16:53 1 Mon Aug 10 21:36:37 2015 192.168.0.16:53 118.16.171.171:38349
[LAN access from remote] from 31.42.22.3:21079 to 192.168.0.16:53 1 Mon Aug 10 21:36:37 2015 192.168.0.16:53 31.42.22.3:21079
[LAN access from remote] from 105.142.40.233:64005 to 192.168.0.16:53 1 Mon Aug 10 21:36:37 2015 192.168.0.16:53 105.142.40.233:64005
[LAN access from remote] from 109.26.240.23:51277 to 192.168.0.16:53 1 Mon Aug 10 21:36:37 2015 192.168.0.16:53 109.26.240.23:51277
[LAN access from remote] from 118.247.210.6:48630 to 192.168.0.16:53 1 Mon Aug 10 21:36:37 2015 192.168.0.16:53 118.247.210.6:48630
[LAN access from remote] from 65.156.154.222:7192 to 192.168.0.16:53 1 Mon Aug 10 21:36:36 2015 192.168.0.16:53 65.156.154.222:7192
[LAN access from remote] from 90.175.168.141:23533 to 192.168.0.16:53 1 Mon Aug 10 21:36:36 2015 192.168.0.16:53 90.175.168.141:23533
[LAN access from remote] from 48.240.16.63:28703 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 48.240.16.63:28703
[LAN access from remote] from 119.47.77.157:14845 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 119.47.77.157:14845
[LAN access from remote] from 124.169.98.24:22892 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 124.169.98.24:22892
[LAN access from remote] from 84.197.114.244:6784 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 84.197.114.244:6784
[LAN access from remote] from 28.52.157.30:54150 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 28.52.157.30:54150
[LAN access from remote] from 3.103.62.160:17262 to 192.168.0.16:53 1 Mon Aug 10 21:36:35 2015 192.168.0.16:53 3.103.62.160:17262
[LAN access from remote] from 119.100.246.134:58192 to 192.168.0.16:53 1 Mon Aug 10 21:36:34 2015 192.168.0.16:53 119.100.246.134:58192
[LAN access from remote] from 60.73.160.227:6007 to 192.168.0.16:53 1 Mon Aug 10 21:36:34 2015 192.168.0.16:53 60.73.160.227:6007
[LAN access from remote] from 24.54.215.210:62703 to 192.168.0.16:61002 1 Mon Aug 10 21:36:34 2015 192.168.0.16:61002 24.54.215.210:62703
[LAN access from remote] from 202.29.239.115:48929 to 192.168.0.16:61002 1 Mon Aug 10 21:36:34 2015 192.168.0.16:61002 202.29.239.115:48929
[LAN access from remote] from 116.192.21.190:64830 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 116.192.21.190:64830
[LAN access from remote] from 116.220.113.215:22929 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 116.220.113.215:22929
[LAN access from remote] from 68.38.158.234:9528 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 68.38.158.234:9528
[LAN access from remote] from 84.89.154.244:16808 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 84.89.154.244:16808
[LAN access from remote] from 86.148.87.77:631 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 86.148.87.77:631
[LAN access from remote] from 4.60.184.250:49010 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 4.60.184.250:49010
[LAN access from remote] from 78.88.44.158:51022 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 78.88.44.158:51022
[LAN access from remote] from 5.50.24.193:8485 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 5.50.24.193:8485
[LAN access from remote] from 16.210.130.172:41552 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 16.210.130.172:41552
[LAN access from remote] from 32.226.162.193:57989 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 32.226.162.193:57989
[LAN access from remote] from 205.134.243.222:1231 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 205.134.243.222:1231
[LAN access from remote] from 205.134.243.222:64273 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 205.134.243.222:64273
[LAN access from remote] from 205.134.243.222:25090 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 205.134.243.222:25090
[LAN access from remote] from 39.37.49.144:32218 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 39.37.49.144:32218
[LAN access from remote] from 33.21.101.246:42528 to 192.168.0.16:53 1 Mon Aug 10 21:36:33 2015 192.168.0.16:53 33.21.101.246:42528
