mrjohncool35
Aug 01, 2015Tutor
C3700-100NAS - Connection issues
Have had the modem/router in one for awhile but it seems glitchy. Firmware Version V1.01.11 I have this current one as a replacement but it seems it may be worse or just as bad as the first ...
ElaineM
Aug 04, 2015NETGEAR Employee Retired
Hi mrjohncool35,
Looks like after replacing the unit, the concern still exists. When did the disconnection start? How many times will it reboot? Do you happen to run a particular application then it will reboot? Or this happens randomly? Did you try using a different modem to verify if it will give you the same problem? Perhaps you could try a test modem from your ISP. Let us know what happens.
mrjohncool35
Aug 05, 2015Tutor
I am unsure how many times a Day it does reboot but i'm concerned with the fact that the router reboots when i open up chrome or another browser and go to access the router with my computer. That right there is a Bug/Flaw in your software causing the hardware to be faulty as well. My devices are 3 Cell phones - Andriod, a Roko Stick, 3 Laptops, 1 Desktop wireless and 1 directly plugged in and a Magic Jack Plus Plugged in.
I create my own Router ID and Pass Phrase for it so it is more secure than most routers.
My concern is the router ID is the issue or I have yet found another Faulty router.
Router ID is similar to: AaaaaAAaaaa!
Router Pass Phrase is: Aaaa 0000 Aaaaa Aaaaa Aaaa!
Of course those are not exactly 100% how it is setup but a good example how I have set my router up to be more secure vs using default settings.
I am unsure if any of the devices listed above would cause a problem. All my computers are Windows 7 systems.
Please advise as to if there is a Firmware update or something else that may be causing this issue. My cable company has stated there was some static or something in my line but it has since then been cleaned up and my Coax is good as the TV's work perfectly fine.
- ElaineMAug 05, 2015NETGEAR Employee Retired
mrjohncool35 All firmware push will be done by the ISP. There is no way to upgrade the firmware manually for your device. Since you have the latest firmware, kindly PM me a copy of your configuration file, logs, event logs and cable connection page for analysis.
- mrjohncool35Aug 10, 2015Tutor
Here is a copy of my logs:
Description Count Last Occurrence Target Source
[LAN access from remote] from 103.3.127.204:19412 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 103.3.127.204:19412
[LAN access from remote] from 66.46.171.227:11841 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 66.46.171.227:11841
[LAN access from remote] from 61.226.246.122:28736 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 61.226.246.122:28736
[LAN access from remote] from 78.104.250.129:38227 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 78.104.250.129:38227
[LAN access from remote] from 35.21.69.162:35276 to 192.168.0.16:53 1 Mon Aug 10 21:37:04 2015 192.168.0.16:53 35.21.69.162:35276
[LAN access from remote] from 123.72.136.139:32029 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 123.72.136.139:32029
[LAN access from remote] from 74.54.102.110:63706 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 74.54.102.110:63706
[LAN access from remote] from 118.53.40.210:4926 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 118.53.40.210:4926
[LAN access from remote] from 106.84.34.140:62772 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 106.84.34.140:62772
[LAN access from remote] from 97.235.108.174:11910 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 97.235.108.174:11910
[LAN access from remote] from 122.232.86.243:19141 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 122.232.86.243:19141
[LAN access from remote] from 110.208.160.24:31674 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 110.208.160.24:31674
[LAN access from remote] from 106.243.246.134:51822 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 106.243.246.134:51822
[LAN access from remote] from 51.171.47.113:38087 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 51.171.47.113:38087
[LAN access from remote] from 40.209.205.16:7348 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 40.209.205.16:7348
[LAN access from remote] from 21.82.111.11:38831 to 192.168.0.16:53 1 Mon Aug 10 21:37:03 2015 192.168.0.16:53 21.82.111.11:38831
[LAN access from remote] from 107.192.97.5:13959 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 107.192.97.5:13959
[LAN access from remote] from 8.159.109.183:31989 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 8.159.109.183:31989
[LAN access from remote] from 26.242.85.87:35131 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 26.242.85.87:35131
[LAN access from remote] from 61.116.97.226:56010 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 61.116.97.226:56010
[LAN access from remote] from 31.70.90.193:38733 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 31.70.90.193:38733
[LAN access from remote] from 54.220.111.138:56130 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 54.220.111.138:56130
[LAN access from remote] from 1.234.226.234:58558 to 192.168.0.16:53 1 Mon Aug 10 21:37:02 2015 192.168.0.16:53 1.234.226.234:58558
[LAN access from remote] from 60.174.18.189:35353 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 60.174.18.189:35353
[LAN access from remote] from 7.95.36.244:12722 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 7.95.36.244:12722
[LAN access from remote] from 22.234.169.53:54537 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 22.234.169.53:54537
[LAN access from remote] from 94.138.161.165:23739 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 94.138.161.165:23739
[LAN access from remote] from 121.121.104.234:23006 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 121.121.104.234:23006
[LAN access from remote] from 81.80.88.61:63709 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 81.80.88.61:63709
[LAN access from remote] from 88.118.250.2:43248 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 88.118.250.2:43248
[LAN access from remote] from 87.62.211.112:32750 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 87.62.211.112:32750
[LAN access from remote] from 91.9.165.153:22957 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 91.9.165.153:22957
[LAN access from remote] from 5.155.184.162:49624 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 5.155.184.162:49624
[LAN access from remote] from 115.155.152.161:32217 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 115.155.152.161:32217
[LAN access from remote] from 5.145.47.188:14558 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 5.145.47.188:14558
[LAN access from remote] from 71.75.165.197:12893 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 71.75.165.197:12893
[LAN access from remote] from 46.49.232.94:17090 to 192.168.0.16:53 1 Mon Aug 10 21:37:01 2015 192.168.0.16:53 46.49.232.94:17090
[LAN access from remote] from 45.61.232.21:16529 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 45.61.232.21:16529
[LAN access from remote] from 42.90.221.84:12298 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 42.90.221.84:12298
[LAN access from remote] from 63.57.83.30:53136 to 192.168.0.16:53 1 Mon Aug 10 21:37:00 2015 192.168.0.16:53 63.57.83.30:53136
[LAN access from remote] from 61.130.232.177:25015 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 61.130.232.177:25015
[LAN access from remote] from 98.193.143.42:21166 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 98.193.143.42:21166
[LAN access from remote] from 114.150.207.246:45860 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 114.150.207.246:45860
[LAN access from remote] from 87.220.200.180:30318 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 87.220.200.180:30318
[LAN access from remote] from 52.102.168.252:4042 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 52.102.168.252:4042
[LAN access from remote] from 104.174.73.163:6401 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 104.174.73.163:6401
[LAN access from remote] from 98.157.59.166:65248 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 98.157.59.166:65248
[LAN access from remote] from 27.6.183.98:60270 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 27.6.183.98:60270
[LAN access from remote] from 5.33.126.241:34611 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 5.33.126.241:34611
[LAN access from remote] from 38.221.231.28:13016 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 38.221.231.28:13016
[LAN access from remote] from 119.233.101.166:21370 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 119.233.101.166:21370
[LAN access from remote] from 18.5.53.224:22506 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 18.5.53.224:22506
[LAN access from remote] from 104.198.146.9:24983 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 104.198.146.9:24983
[LAN access from remote] from 2.182.29.127:8427 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 2.182.29.127:8427
[LAN access from remote] from 4.56.174.45:46237 to 192.168.0.16:53 1 Mon Aug 10 21:36:59 2015 192.168.0.16:53 4.56.174.45:46237
[LAN access from remote] from 59.67.28.163:37161 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 59.67.28.163:37161
[LAN access from remote] from 40.19.7.37:21835 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 40.19.7.37:21835
[LAN access from remote] from 58.199.3.198:30548 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 58.199.3.198:30548
[LAN access from remote] from 113.151.65.9:8761 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 113.151.65.9:8761
[LAN access from remote] from 18.126.141.149:45201 to 192.168.0.16:53 1 Mon Aug 10 21:36:58 2015 192.168.0.16:53 18.126.141.149:45201
[LAN access from remote] from 205.134.243.222:51860 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 205.134.243.222:51860
[LAN access from remote] from 205.134.243.222:41734 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 205.134.243.222:41734
[LAN access from remote] from 65.172.148.244:5710 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 65.172.148.244:5710
[LAN access from remote] from 111.131.103.191:17607 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 111.131.103.191:17607
[LAN access from remote] from 43.7.32.225:29935 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 43.7.32.225:29935
[LAN access from remote] from 103.151.80.42:7514 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 103.151.80.42:7514
[LAN access from remote] from 35.6.78.81:37469 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 35.6.78.81:37469
[LAN access from remote] from 83.110.62.135:58211 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 83.110.62.135:58211
[LAN access from remote] from 62.14.214.73:20583 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 62.14.214.73:20583
[LAN access from remote] from 100.180.72.196:4142 to 192.168.0.16:53 1 Mon Aug 10 21:36:57 2015 192.168.0.16:53 100.180.72.196:4142
[LAN access from remote] from 124.53.89.10:20342 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 124.53.89.10:20342
[LAN access from remote] from 8.175.140.207:39981 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 8.175.140.207:39981
[LAN access from remote] from 107.130.253.68:53834 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 107.130.253.68:53834
[LAN access from remote] from 85.39.241.207:39455 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 85.39.241.207:39455
[LAN access from remote] from 70.91.26.93:42259 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 70.91.26.93:42259
[LAN access from remote] from 52.129.27.220:33502 to 192.168.0.16:53 1 Mon Aug 10 21:36:56 2015 192.168.0.16:53 52.129.27.220:33502
[LAN access from remote] from 72.63.184.42:18090 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 72.63.184.42:18090
[LAN access from remote] from 62.29.27.19:38221 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 62.29.27.19:38221
[LAN access from remote] from 80.136.219.98:31348 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 80.136.219.98:31348
[LAN access from remote] from 211.234.100.117:41842 to 192.168.0.16:5900 1 Mon Aug 10 21:36:55 2015 192.168.0.16:5900 211.234.100.117:41842
[LAN access from remote] from 100.234.115.211:15273 to 192.168.0.16:53 1 Mon Aug 10 21:36:55 2015 192.168.0.16:53 100.234.115.211:15273
[LAN access from remote] from 83.142.78.187:62423 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 83.142.78.187:62423
[LAN access from remote] from 97.243.36.10:58864 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 97.243.36.10:58864
[LAN access from remote] from 115.166.10.234:61494 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 115.166.10.234:61494
[LAN access from remote] from 62.38.17.160:35820 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 62.38.17.160:35820
[LAN access from remote] from 66.240.44.109:45133 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 66.240.44.109:45133
[LAN access from remote] from 92.233.43.195:58261 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 92.233.43.195:58261
[LAN access from remote] from 96.55.65.67:65457 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 96.55.65.67:65457
[LAN access from remote] from 124.112.168.76:40750 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 124.112.168.76:40750
[LAN access from remote] from 35.119.139.150:53380 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 35.119.139.150:53380
[LAN access from remote] from 217.160.206.182:56040 to 192.168.0.16:5900 1 Mon Aug 10 21:36:54 2015 192.168.0.16:5900 217.160.206.182:56040
[LAN access from remote] from 75.215.194.86:22534 to 192.168.0.16:53 1 Mon Aug 10 21:36:54 2015 192.168.0.16:53 75.215.194.86:22534
[LAN access from remote] from 92.88.102.211:7557 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 92.88.102.211:7557
[admin login] from source 192.168.0.12 1 Mon Aug 10 21:36:53 2015 0.0.0.0:0 192.168.0.12:0
[LAN access from remote] from 36.55.176.4:63090 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 36.55.176.4:63090
[LAN access from remote] from 111.165.117.53:21121 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 111.165.117.53:21121
[LAN access from remote] from 17.86.30.28:16072 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 17.86.30.28:16072
[LAN access from remote] from 23.56.245.237:8799 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 23.56.245.237:8799
[LAN access from remote] from 37.173.16.22:22896 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 37.173.16.22:22896
[LAN access from remote] from 99.107.57.86:65068 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 99.107.57.86:65068
[LAN access from remote] from 88.75.92.158:2870 to 192.168.0.16:53 1 Mon Aug 10 21:36:53 2015 192.168.0.16:53 88.75.92.158:2870
[LAN access from remote] from 76.254.52.168:52388 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 76.254.52.168:52388
[LAN access from remote] from 107.213.130.141:22585 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 107.213.130.141:22585
[LAN access from remote] from 31.53.87.213:37951 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 31.53.87.213:37951
[LAN access from remote] from 29.224.18.7:19399 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 29.224.18.7:19399
[LAN access from remote] from 74.25.41.157:48079 to 192.168.0.16:53 1 Mon Aug 10 21:36:52 2015 192.168.0.16:53 74.25.41.157:48079
[LAN access from remote] from 44.109.134.80:56618 to 192.168.0.16:53 1 Mon Aug 10 21:36:51 2015 192.168.0.16:53 44.109.134.80:56618
[LAN access from remote] from 32.26.211.95:4501 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 32.26.211.95:4501
[LAN access from remote] from 15.247.6.136:9334 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 15.247.6.136:9334
[LAN access from remote] from 96.250.213.221:38355 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 96.250.213.221:38355
[LAN access from remote] from 70.61.46.152:47378 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 70.61.46.152:47378
[LAN access from remote] from 126.59.79.69:18877 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 126.59.79.69:18877
[LAN access from remote] from 6.98.187.213:50841 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 6.98.187.213:50841
[LAN access from remote] from 97.225.80.105:4653 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 97.225.80.105:4653
[LAN access from remote] from 35.109.56.2:31964 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 35.109.56.2:31964
[LAN access from remote] from 44.148.166.243:65051 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 44.148.166.243:65051
[LAN access from remote] from 74.228.165.90:14628 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 74.228.165.90:14628
[LAN access from remote] from 29.144.81.107:35467 to 192.168.0.16:53 1 Mon Aug 10 21:36:50 2015 192.168.0.16:53 29.144.81.107:35467
[LAN access from remote] from 100.51.208.180:38684 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 100.51.208.180:38684
[LAN access from remote] from 74.191.223.31:29343 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 74.191.223.31:29343
[LAN access from remote] from 92.41.74.132:216 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 92.41.74.132:216
[LAN access from remote] from 50.184.181.124:6382 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 50.184.181.124:6382
[LAN access from remote] from 128.125.98.102:24930 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 128.125.98.102:24930
[LAN access from remote] from 111.216.220.52:47590 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 111.216.220.52:47590
[LAN access from remote] from 38.132.254.67:18765 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 38.132.254.67:18765
[LAN access from remote] from 54.121.55.121:41579 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 54.121.55.121:41579
[LAN access from remote] from 57.200.51.40:42168 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 57.200.51.40:42168
[LAN access from remote] from 56.56.105.17:55169 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 56.56.105.17:55169
[LAN access from remote] from 90.190.123.48:11950 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 90.190.123.48:11950
[LAN access from remote] from 24.138.57.197:26841 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 24.138.57.197:26841
[LAN access from remote] from 62.90.223.93:23059 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 62.90.223.93:23059
[LAN access from remote] from 4.59.147.146:39432 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 4.59.147.146:39432
[LAN access from remote] from 12.251.254.197:5821 to 192.168.0.16:53 1 Mon Aug 10 21:36:49 2015 192.168.0.16:53 12.251.254.197:5821
