Psyblade
Dec 27, 2014Aspirant
C3700-100NAS Drops Connections and Glitchy
Just got this modem-router combo. Main PC is connected by ethernet cable and doesn't seem to lose connection, but Day of Defeat periodically freezes and jumps during the game for a split second. Wifi...
Psyblade
Feb 09, 2015Aspirant
I was able to check the channels in the neighborhood and I tried some that were in less use, but it did not make any difference. I went back to my old docsis 2.0 and dlinl DIR-655 and things are back to normal. Even with the docsis 3.0 C3700 I didn't notice much difference in how downloads acting in real life. The cox folks said they had had some trouble with modem/router combos, no particular brands or models. At least I was able to get my money back.
calgecko
Nov 26, 2015Aspirant
I've been having similar problems with my C3700 (I have Comcast Xfinity), where my laptop will connect to wifi, but there's no internet connection, then if I change from the 5g to 2.4 or vice-versa, it'll get connectivity.. it doesn't seem to be a solid, reliable product
- DarrenMDec 01, 2015Sr. NETGEAR Moderator
Hello calgecko
Have you tried clearing out you wireless network lists in your laptop then trying to reconnect to the network it could be some old setting it had saved when trying to connect to the network. Also you may want to try changing channels on the wireless network. Last thing I would so is try to change the SSID I have seen this work for some people.
DarrenM
