dirttrack
Apr 22, 2022Tutor
C3700-100NAS
My C3700 Modem Router has never been able to update the firmware. I am still on version V1.01.05. Spectrum has approved version V2.02.18 and they tell me that they are attempting the download. My...
dirttrack
Apr 22, 2022Tutor
The router is functioning but I want the updates. I am far behind any fixes they may have done for security
Apr 22, 2022Guru - Experienced User
Problem with it is, a netgear engineer can't do anything either. With modem/router combo devices, the firmware is part of the provisioning from the ISP. So when they push your service package with the speeds, it has the firmware as part of it.
Its part of the docsis spec and is controlled by spectrum.
So you can try contacting spectrum again or seeing if you can get a higher level tech support from them.
You can try contacting them to get the firmware.
One thing to keep in mind, is that most of the isp's are pushing for docsis 3.1 devices. The C3700 is an older N600 device that only has a docsis 3.0 modem thats a 8x4 device. Quite a bit older and the very base model spec for docsis 3.0. I'm not sure how hard spectrum is going to be to get it updated.
- dirttrackApr 22, 2022Tutor
I had a long conversation with higher up than just normal tech support. Spectrum has an approved list of firmware versions for various models. I am far behind what is listed as approved. According to them they must verify the download before it is approved. So why does my modem/router "return incompatible SW file". I tried to get an answer if ANYONE with a C3700 has had their firmware successfully updated but no luck getting that answer.
I have 7 lines in my error log after a reboot the first two I already stated. I am hesitant to post the others as I'm not a network engineer so I don't want to expose something I shouldn't. Not sure if they would be helpful???
