erskumaresan
Dec 28, 2015Aspirant
C3700 CABLE ROUTER is not opening many of web sites with TWC ISP
Hi, I bought a new Netgear C3700 cable modem router box and configure it to the time warner cable. I am able to connect to the internet but I am unable to any of the web sites other than face boo...
DarrenM
Dec 28, 2015Sr. NETGEAR Moderator
Hello erskumaresan
Hace you tried to change the DNS server it could be a issue with there DNS server I would suggest trying the google DNS with 8.8.8.8 8.8.4.4
https://developers.google.com/speed/public-dns/docs/using?hl=en
DarrenM
erskumaresan
Hi,
Thanks for your reply, but still the issue is not resolved.
I am able to connect to the internet but the issue is I am unable to open any of the web sites.
- DarrenMDec 28, 2015Sr. NETGEAR Moderator
Have you tried doing a factory reset to the modem yet?
DarrenM
- erskumaresanDec 28, 2015Aspirant
Hi,
Not Yet, I am unable to find a Factory reset button on this model router.
My Frim Id is V1.01.11.
It is a small pin hole on the back of the modem you hold it in for 10 seconds with a pen or paperclip that will do a factory reset on the device.
DarrenM
