Seanmccat
Sep 04, 2015Aspirant
c3700-can't conect
I bouth a c3700 back in December. It was working fine for the most part until last Monday. At that point, while it says I have a connection, I can not connect to any pages. It does not matter if ...
Seanmccat
Actually, I can connect to the internet on the guest network, but not through the ethernet cable or the other networks.
DarrenM
Sep 08, 2015Sr. NETGEAR Moderator
Hello Seanmccat
If you tried factory resets and still cant connect it may be a hardware malfunction I would suggest contacting netgear support to check. If its still under warranty possible to get a RMA if its not working properly.
DarrenM
