Larry686
Apr 23, 2019Aspirant
C3700 can't load certain websites on android and ios devices
Problem started about 4 weeks ago. tandyleather.com and pcmag.com started taking from 2 minutes to 5 minutes to load pages on some devices. All other sites load normally. It has to be my wifi as thes...
Apr 24, 2019Guru - Experienced User
Try a different modem...
Larry686
Apr 24, 2019Aspirant
I want to fix this one. Had it almost 2 years without any problems. This has been a problem only the last 30 days or so. What could have changed?
- DarrenMApr 30, 2019Sr. NETGEAR Moderator
Have you tried to use load the desktop site on the mobile devices? Also, have you tried to change the DNS on the phones and tablets wireless settings?
DarrenM
- Larry686Apr 30, 2019Aspirant
Yes to both. Didn't help, but thanks for responding.
- Larry686May 02, 2019Aspirant
Didn't solve the problem, but found a workaround. Downloaded an app called dnspipe by Frostnerd.com. I'm not sure exactly how it works, but with it active, both the problem sites load normally.
