DarrenMSr. NETGEAR ModeratorApr 20, 2016 Hello Rollin Have you tried to login using 192.168.0.1? DarrenM
RollinAspirant to DarrenMApr 21, 2016Have done that and used several other addresses. But no difference. Can the modem be reset? Are other people having this same issue?
TheEtherGuru to RollinApr 21, 2016Try to find the IP address of your router using this method (link). If that fails, then reset the modem by pushing the physical reset button for 8 to 10 seconds until the lights flash off and on.
