krward
Oct 08, 2014Follower
c3700 connection issue
Well I tried Netgear Support and they were zero help.... I have the C3700 - 100NAS Everything worked fine for a couple of months but now nothing except my 2 computers connect and works like normal ...
alvaradoha
Nov 05, 2015Aspirant
I too have had issues with the c3700 and have mediacom as my ISP. I have great connectivity but my router keeps reverting to bridge mode and wont go into router mode. I called support and they are no help. I will never buy a netgear device again.
DarrenM
Nov 10, 2015Sr. NETGEAR Moderator
Hello alvardoha
Have you tried to factory reset and then try to change it to router mode.
DarrenM
- calgeckoNov 26, 2015Aspirant
Glad to see I'm not the only one having problems with the C3700 and Comcast.. it sucks that it's such a problem and Netgear can't step up and make it right. I've only had this device for about 2 or 3 months now, so I'm sure I can't return it to where I bought it. I'm tired of unreliable and dropped signals, especially since I have several cameras set up in my house on my wifi network. I appreciate the insight about the 1 star versus 3 star rating system.. looks like I need to go do some more research and find a replacement for this piece of junk.
