krward
Oct 08, 2014Follower
c3700 connection issue
Well I tried Netgear Support and they were zero help.... I have the C3700 - 100NAS Everything worked fine for a couple of months but now nothing except my 2 computers connect and works like normal ...
Boyce85
Apr 19, 2016Aspirant
- JdcrowJun 22, 2016Aspirant
I had similar issues, my 2.4g internet and direct lines work, but it seems to only be a 5g issue.
I looked everywhere and couldn't find a fix, so I decided to try it myself.
I cleared all event and access logs on the device, then I use a WiFi analyser to find a better channel and changed the channel to a more clear one.
I then rebooted and now on my tablet and cell phone the 5g works great again. On my wife's inam still having minor issues. Hope this helps some of you.
