Scubaluke50
Feb 03, 2017Follower
C3700 connection
I have recently started having trouble with my router model C3700-100NAS. My devices (phone and laptop) connect to the signal. However, when trying to get onto the Internet the eventually times out and gives me an error message that there is no Internet connection. The network diagnostic report says it's either the device or resource. Was going to do a factory reset but can't find the reset button on the model that I have. Willing to listen to any suggestions. Thanks.
1 Reply
- DarrenMSr. NETGEAR Moderator
The factory reset button should be a pin hole on the back or the bottom of the modem. You also may want to post the logs of the modem when this happens may find whats going on.
DarrenM
