dbrits
Jul 22, 2016Initiate
C3700 Deafult ReadyShare Password Not Working
I'm trying to utilize my brand new C3700's ReadyShare feature for a very basic NAS. My goal is to implement password protection on the network folder, but when I do so, I cannot access the files usin...
DarrenM
Jul 26, 2016Sr. NETGEAR Moderator
Hello dbrits
From this article I linked it uses the login the same as your routers so of you have changed your routers login password you will want to use that when it asks for that info in ready share or try to change your routers login password and then try that on readyshare.
http://kb.netgear.com/app/answers/detail/a_id/20129?cid=wmt_netgear_organic
DarrenM
ruijay
Aug 22, 2016Aspirant
Hello there,
I have exactly the same issue. I just bought this router= C3700. I changed the admin password and everything works fine, except my NAS. I can access my hard drive with no issue when I set up access to ALL. But when I change the access to only admin, I get an error (wrong username and password).. I tried changing the admin password to a short, long, more complicated passwords and still no luck. Not sure if this is an issue with the router or it is something with the password I have set up.
