JD007
Oct 29, 2015Follower
C3700 drops internet connection
 I have a C3700-100NAS that has worked good for about 8 months now, but lately it's been dropping the internet connection, almost on a daily basis and I have to reboot it. I just want to know if it's ...
DarrenM
Nov 02, 2015Sr. NETGEAR Moderator
Hello Jd007
is the Internet connection dropping over Ethernet or wifi or both? You also may want to check to see if you have a cable splitter on the line and try removing it to test to see if that is causing the issue.
DarrenM
