mfs
Nov 21, 2016Aspirant
C3700 Firmware Update
I have a C3700-100NAS N600 Cable Modem with firmware version V1.01.11. I can not establish a PTPP VPN connection to my office. It appears that there is a newer firmware version (2.02.08) that suppo...
DarrenM
Jul 06, 2017Sr. NETGEAR Moderator
Hello sysatek
The ISP CMTS server pushes the firmware to the modem typically in the middle of the night it will push it and then cause the modem to reboot and it will be up to date. So yes the iSP does the update but the Tech himself can not do it typically it is just uploaded on there server and pushed automatically during maintenance periods.
DarrenM
sysatek
Jul 06, 2017Aspirant
>The ISP CMTS server pushes the firmware to the modem typically in the middle of the night it will push it and then cause the modem >to reboot and it will be up to date. So yes the iSP does the update but the Tech himself can not do it typically it is just uploaded on >there server and pushed automatically during maintenance periods.
I understand that the Tech does not push the firmware updates, however the issue I described relates to the router reverting back to factory defaults without My intervention. The ISP Tech indicated they did not push out update, and I certainly do not have the flash image to perform the update Myself, so the point I was making was that either the Tech was unaware of an update process inside the ISP or the update was pushed by unknown actor, or possibly even no flash was pushed at all, and might imply a breach in the products security, and hence they left it freshy tainted for me to see. The unit is not an ISP provided unit, as I purchased the unit and initally setup the config and passwords and such. So finding the unit defaulted to factory settings is a real cause of concern. Imagine if it was your device on your LAN and the ISP indicated they performed no intervention. Would you have any confidence is the security of the device?
Jerry
