ck95
Oct 11, 2015Aspirant
C3700 giving random lag spikes
When using my router I notice that when I play games I will experience a lag spike once every minute or 2 that last about 3 seconds. It happens on Netflix and other streams too except it will downgra...
ck95
Oct 12, 2015Aspirant
My speed is 50 Mbps down. I've tried both wired and wireless connection and I still have the same problem. There is no splitter isntalled it's a straight connect to the cable port.
vkdelta
Oct 12, 2015NETGEAR Employee Retired
do you have event logs and power table values? Can you please post them here? probably you have Timeouts which are causing these spikes.
also, can you please ping 75.75.75.75 for an hour and see if you spikes?
A tool to do it better than DOS command prompt.
http://emcosoftware.com/ping-monitor
- ck95Oct 12, 2015Aspirant
